polyflow screw rotation and moving ahead
    • jishnu94.deu
      Hi
      for now i have given a rotaional motion to the screw where it is fixed . But in reality the screw is also moving ahead .
      so is it possible to rotate and move the screw ahead at the same time ?
      i could only see the translational velocity in the definition of moving parts , did not see the new location to which it can be moved.
      please help
    • Prashanth
      Hello!
      I assume you are simulating a screw extruder (a steady case or evolution). You can set both angular and translational velocity. I don't think you can specify any other settings like you mentioned above. Maybe this will help:
      https://ansyshelp.ansys.com/Views/Secured/corp/v231/en/poly_pf/pf_ug_sec_moving_guidelines_transient.html
