September 18, 2019 at 7:37 am
September 18, 2019 at 11:03 am
Naresh Patre
Ansys EmployeeHello Anssi
It looks like the Polygon tool is disabled when the Sketch tab is activated using beta option. I will check with the development team and let you know. Meanwhile, you can disable the beta option and use the sketching tools from the Design tab.
September 18, 2019 at 11:28 am
anssi.mustonen
SubscriberHi Naresh, ok, thank you for your reply.
September 19, 2019 at 7:31 am
Naresh Patre
The polygon tool is currently not compatible with the algorithm used for defining constraints. Hence, this tool was disabled in 2019 R2 and then removed in 2019 R3. The development team may revisit this feature in future. Till then, you can disable the beta option and use the polygon tool from the Design tab.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1236
592
