February 15, 2023 at 10:20 pm
Rajesh
SubscriberI need help with connecting my points in spaceclaim. Is it possible to connect points when they are loaded via script in spaceclaim? The shape is realy simple. I dont want to use my methodology of importing points by rather use script to connect points in 3D when points are already loaded. Are there any tough users to help? Points should be connected by path, I mean one polyline would be OK.
February 16, 2023 at 5:02 am
Keyur Kanade
Ansys EmployeeYes, this is possible. Text file will have following format.
Then you can import it in SpaceClaim Assembly - File.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
February 16, 2023 at 5:04 am
Keyur Kanade
Ansys EmployeeRecommend to try on a simple case and then use your case.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3930
2649
1869
1272
610
