Discovery Import
Discovery Import
Polymer Blow Molding Simulation
    • Pkulal
      I am working on Blow simulation for tank shells on Discovery AIM. i tired to simulate some test cases where the mold is fixed and the parison sheet moves into the shell, but i am unable to solve the physics. Please help.
    • Naresh Patre
      Hello Pkulal
      Can you please share the concerned project file for investigating the issue? I will send you a secure transfer link for uploading the model. Please send the archived file. Detailed information on archiving the project file can be found in this article.
    • Pkulal
      Please find the file.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello Pkulal
      Thanks for sending the file. I made following modifications to the model:
      1. Increased the viscosity to 50000 PaS
      2. Reduced pressure to 0.008 MPa with a negative (-) sign
      3. Under Contact 1, changed Mold body side to "Back".
      This helped to solve the model. Can you please try it out at your end?
    • Pkulal
      Hello Naresh,
      Hope you are fine.
      i have started to do some blow simulations again on some tanks and i have set up the physics based on your suggestions but i am able to solve it partially, after 0.5 sec i am getting some error called "Error in system util module". please help
      • Naresh Patre
        answered this question through separate question
Viewing 4 reply threads
