June 19, 2019 at 11:44 pm
s3740222
SubscriberHI All,
I am trying to design a linear generator on ANSYS 19.2. The problem is when I try to add winding to the excitation there is no option of clicking 'OK'. When I press 'Add Winding' a box come up with few values and written beneath ' user default'. There is no option of clicking OK or CANCEL.
That's why I am not able to add winding to the excitation. CAn somebody please help me with this?
June 20, 2019 at 12:15 am
mchristi
Ansys EmployeeThis is a bug in R19.2. The OK button is missing in Add Winding panel!
Workaround: Just hit the enter key on the keyboard. If you then reopen the winding panel, the OK button is restored.
June 20, 2019 at 12:20 am
June 20, 2019 at 1:35 am
s3740222
SubscriberHi again.. Facing one more problem now. There is no option of edit circuit when I am trying to add an external circuit. It is mentioned that you already have a circuit in C/ANSYS/TEM?65762637257 like this a big number. I cleared all such circuits from temp folder but still, there is no option of editing circuit. It just says create a circuit.
- Maxwell, HFSS or Q3D?
- Error
3740
2570
1785
1236
594
