Discovery Import
Discovery Import
Poor GPU memory usage and inadequate fidelity
    • ahobbs
      I have a GP100 with 16GB of RAM. When running fluids at max fidelity the memory usage is less than 8GB.  GPU load is 85% but I'm not able to resolve key features in the model (thin baffles).  In this particular model the min feature size is 10mm but I have baffles around 4mm.  This is a significant limitation.  Is there way to increase resolution and use more of the GPU memory?
      I've reduced the size of the domain as much as I can.
    • Subashni Ravichandran
      Hello Andrew Hobbs
      There is a certain cap on the percentage of GPU used in Discovery Live.
      I would recommend you to follow this discussion on a similar query. Here, there is a clear explanation as to why there is a cap on GPU usage.
      I hope this clarifies your query.
    • ahobbs
      Thanks, I appreciate that, but from a user perspective 50% memory use seems overly conservative.  The second related issue is that it is impossible to resolve important, thin internal geometry which are below the feature threshold.  Discovery is a great product that I would like to use more but the resolution problem which is exacerbated by the memory limits mean I can only use it on very simple problems.  Without some means of local refinement the applicability of Discovery is very limited.
      Andrew Hobbs
      It may not be 50% per se as in your case you can see that 85% is being used. Although, I'm not sure if there is a specific percentage as such or if it is randomly determined.
      Our developers are working hard on making thin surfaces a possibility in Discovery Live. Hopefully, we will see some improvements in the near future. Thank you for your inputs. We're glad you like our products.
    • ahobbs
      Subashni Glad to hear.... happy to help with this feature development if you need beta testers
Viewing 4 reply threads
