March 24, 2022 at 8:35 pm
_1billy
Subscriberhello , i have problem with mesh , may anyone help me with this problem
March 25, 2022 at 2:51 amKeyur Kanade
Ansys EmployeeThe min orthogonal quality should be above 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh." target="blank">
First check the locations of the bad elements. Please see following video for the same.
Once you have locations, please check if you can improve mesh using different mesh sizing. Please see following video.
If this does not help, you may need to check if you can use pinch control or virtual topology.
If this does not help, please go to geometry and modify or simplify geometry at those locations in SpaceClaim.
March 25, 2022 at 12:25 pm
_1billy
Subscribermin orthogonal quality is 0.15, but my problem is solid domain mesh is not accurate even i use small element size
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2156
1359
1150
462
