Tagged: fluent, shock, shockwave, supersonic, supersonic-flow
March 7, 2022 at 10:37 pm
mmmaada00
SubscriberI have simulating a oblique shockwaves in a channel with a terminating shock with the aim of analys8inig the total pressure loss. However, the resolution of the shock(s) in the solution is very poor (I have included an image below).
I believe the mesh is sufficiently fine and has a high cell count with a good element quality. I am also using a density based solver.
Could anybody offer help as to what I may do to fix this issue?
March 8, 2022 at 10:06 amMurari Iyengar
Ansys EmployeeHi Can you post a screenshot of the image? Do not attach the image as we cannot open any attachments/links. You can also take a look at the "Courses" at the top of the page. There are a few Supersonic Flow tutorials which might be helpful for you.
March 8, 2022 at 10:21 amMarch 8, 2022 at 11:29 amRob
Ansys EmployeeThat looks pretty weird. Can you replot with node values off and also plot Mach Number?
March 8, 2022 at 1:43 pmMarch 8, 2022 at 2:21 pmRob
Ansys EmployeeCan you display mesh only at that location?
March 8, 2022 at 3:10 pmMarch 8, 2022 at 4:11 pmRob
Ansys EmployeeThanks, I was double checking for a discontinuity (interface) as I don't think resolution is necessarily to blame for the result. Is the solution well converged, and is it steady or transient?
March 8, 2022 at 6:12 pmmmmaada00
SubscriberIt is a steady simulation. The solution is also struggling to converge fully with most residuals around 1e-3 despite using higher order discretization. I should add that it is implicit and using AUSM flux type
March 9, 2022 at 10:00 amRob
Ansys EmployeeTry using the Higher Order Term Relaxation and drop the Courant Number. I suspect the problem is convergence related. Should the shock be stable? I'm not an expert in shocks as in chemical engineering if it's going that quickly it's gone wrong....
March 9, 2022 at 1:42 pmmmmaada00
SubscriberWeirdly, using high order term relaxation actually worsens convergence. The shock is and should be stable so I am a bit perplexed on how to achieve better convergence
Viewing 10 reply threads- You must be logged in to reply to this topic.
2518
2064
1279
1094
456
