Discovery Import
Discovery Import
Porous block
    • dinakara.manjunathaswamy
      Hello, I am working on porous block in Discovery 2021R2 and comparing the results obtained in fluent,  I have one doubt regarding the porous block properties, I just want to know an ideal scenarios where Isotropic and Bidirectional properties are defined for porous block, or a document regarding thee properties would be helpful.
    • Charudatta Bandgar
      Hello Dinakara
      Let me get back to you.
      Regards.
      Hello Dinakara
      You can find more information here in the Discovery documentation. For Isotropic material properties and bidirectional properties, check the links provided. Let me know if anything particular you would want to know.
      Regards.
      Dinakara
       I am not sure if I understood this correctly. Are you looking for an example, as to when using isotropic/bidirectional properties be appropriate?
        Charudatta Bandgar Thanks. Yes, you got my point, I just want to see examples. Like as I explained I am comparing Fluent results with Discovery results, I just want to better my results in Discovery so it closely matches with Discovery results, so I was looking for some examples.
        Regards
        Dinakara Let me see if there are any examples.
        Regards.
      Hello Dinakara
      Please go through the tutorial.
        Charudatta Bandgar Thanks a lot
Viewing 4 reply threads
