3D Design
3D Design
Porous Media
    • hrivera2
      My team and I are currently experimenting, we have to find the thermal conductivity of porous media. I'm not sure how to model a porous media into a CAD is there way to do it?
    • CFDisGreat
      You make a simple (non-porous) domain in DesignModeler or any CAD software and then in FLUENT (or any solver) set a porous (properties) domain to your geometry and define the permeability an porosity of your designed porous medium.
    • Keyur Kanade
      You need to create geometry as you create for non porous zones.
      The porous properties will be applied in Fluent.
      Please check following section in help
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_Fluid.html%23flu_ug_Fluid
      Keyur
