October 15, 2018 at 3:10 am
mozeer
SubscriberHi all,
I am doing an analysis for a storm water trap which has a basket for trapping pollutants. I need to simulate the basket as a porous media. But I am always having errors or the continuity is diverging.
I wanted to know if we can simulate porous media on VOF, or what model is best? I am currently using VOF and K-epsilon for the model.
Thanks
October 15, 2018 at 4:37 am
Keyur Kanade
Ansys EmployeePlease make sure that you have refined the mesh. Please reduce your time step size and check.
Keyur
October 15, 2018 at 4:44 am
October 15, 2018 at 6:23 am
DrAmine
Ansys EmployeeYes porous media can be used with the VOF model
October 15, 2018 at 10:29 am
Karthik R
AdministratorHello,
If you are still having convergence, please elaborate more on your set-up. You might want to add more about the geometry, show the mesh and boundary conditions, and describe your initialization. I'd also recommend that you provide some more information on the porous media treatment in your model. This way, we will be in better shape to help you.
Thank you.
Best Regards,
Karthik
October 16, 2018 at 5:24 am
mozeer
Subscriberthis is my geometry, its a storm water trap with an internal and external chamber. the bottom part of the internal chamber has a basket (the brown and green part, the brown part is solid since i want to simulate the basket as half full. the green part is my porous media volume)
in fluent I am putting the following parameters:
Type: Pressure-based
Velocity Formulation: Absolute
Time: Transient
gravity -9.81
VOF multiphase model
N of Eulerian Phase: 2
Formulation: Explicit
Interface Modelling: Sharp
k-epsilon realizable turbulence model
Phase 1: air
Phase 2: water
Surface tension: 0.072 constant
cell zone conditions
i have got the values for porous media from experimental work, plotting pressure against velocity as per Workbench guide.
Boundary Conditions:
Water Inlet (velocity-inlet type)
V: 0.45 m/s
Initial Pressure: 0
TKE: 1
Epsilon: 1
Phase 2 fraction: 1
Outlet (pressure outlet)
top (pressure outlet)
Solution Methods:
Pressure-Velocity Coupled (i have tried PISO as well)
Pressure: PRESTO!
Momentum: Second Order Upwind
Volume Fraction: Compressive
TKE: First Order Upwind
Turbulent Dissipation Rate: First Order Upwind
Transient Formulation: First Order Implicit
Solution Control:
Flow Courant: 200
Eexplicit RF
Momentum: 0.3 (i have tried the default as well)
Pressure: 0.3
Under RF
Density: 1
Body Forces: 0.5
TKE: 0.6
TDR: 0.6
Turbulent Viscosity: 0.5
Discrete Phase: 0.9
std Initialization from inlet
Time step size: 0.001(I have tried 0.01 as well)
N of time step: 1000000
would be great if you could help.
Thanks
Ikhlass
October 16, 2018 at 5:42 am
Keyur Kanade
Ansys EmployeeWhat is mesh quality? Please use Quality option in Fluent to check quality. Also check the mesh in Fluent before proceedings.
Did you patch the vof after initialization? Please do it before you start iterations.
Please use PISO.
Please increase urfs.
For time step, you can calculate ((Vcell_min)1/3)/vel
Please set time step less than this value.
You can always get min cell volume when you check the mesh in Fluent.
If divergence occurs, please decrease time step by factor of 10.
Keyur
October 16, 2018 at 6:00 am
October 16, 2018 at 6:02 am
October 16, 2018 at 6:12 am
Keyur Kanade
Ansys EmployeeThe quality is really bad. You can improve it using Fluent Meshing as follows.
Please open Fluent in Meshing Mode.
Go to Mesh --> Tools --> Auto Node Move
Set Quality Measure as Inverse Ortho
Select all boundary zones.
Use 5 iterations
Click apply.
Save .msh file and read in Fluent.
As you are using Workbench meshing, you need to find out where these low quality elements are. Please select orthogonal quality and plot histogram. Then you can click in histogram to see bad elements in the graphics. Then you may need to modify the geometry in SpaceClaim or use virtual topology in Meshing or may be use local sizing to refine the mesh further. Once done, generate mesh and check the quality before proceed.
Check following video which may help.
Hope this helps.
Keyur
October 16, 2018 at 8:45 am
Ansys EmployeeI suspect the poor cells are where the pipes go through the casing. You may also be better off using a thin wall and using a porous jump rather than porous media. Hard to tell from the images, and we're limited in how much detailed help we can give in an open forum.
Is the brown volume to assist in the initialisation, or when you say the basket is full do you mean the unit has part filled with debris?
October 16, 2018 at 9:13 am
mozeer
SubscriberI cant find out where is the auto node move. is that in the previous version?
October 16, 2018 at 9:15 am
mozeer
SubscriberHi Thanks for your reply. I will look into the porous jump ans see if i can use that.
Is there any way of me getting more detailed help, I am kind of stuck with these divergence.
the brown volume is solid in the geometry itself, not fluid, and this is representing the debris.
I have used another model as well using the whole basket volume as the porous media, and not the thin wall. I am still getting divergence.
October 16, 2018 at 10:34 am
Karthik R
AdministratorHello,
Auto node move is part of Fluent Meshing. You will find this option when you right click on the 'Mesh objects' to find the Auto Node Move feature in Fluent meshing.
If you are looking for more video to learn Fluent meshing, we can show you some online resources. If you are more familiar with WorkBench meshing, please use this tool to improve your mesh quality. Please follow the video shared by Keyur to obtain necessary mesh statistics during meshing.
However, Keyur's point was that you will certainly have to improve your mesh to avoid divergence of your solution. It is always important to remember that a few bad cells can prevent your solution from converging. You might also want to include some line / surface / point monitors to understand your divergence better.
If you have not already watched these, I'd highly recommend going through them first. They will help you understand how you can improve the orthogonal quality of your mesh. This is a 4-part video series on Hex meshing.
I hope this helps.
Best Regards,
Karthik
October 16, 2018 at 11:41 am
mozeer
SubscriberThanks for that, I am improving my mesh quality now, I hope that it will not converge anymore.
October 16, 2018 at 12:42 pm
October 16, 2018 at 1:01 pm
Keyur Kanade
Ansys EmployeeHello,
What is new quality of mesh?
Once you improved mesh, did you define all bcs and settings again? Did you patch again?
Keyur
October 16, 2018 at 1:56 pm
October 16, 2018 at 2:06 pm
Ansys EmployeeUse Skewness, Aspect Ratio and Orthogonal skew(?) to check. Element Quality is for the Mech solver and is meaningless for Fluent.
October 16, 2018 at 2:08 pm
Keyur Kanade
Ansys EmployeePlease check orthogonal quality.
Keyur
October 17, 2018 at 1:42 am
October 17, 2018 at 3:20 am
Keyur Kanade
Ansys EmployeeYes, quality looks ok now.
Once get into Fluent, please 'Check' the mesh and 'Quality'.
Please cross check if all settings are correct as discussed in previous posts. Initialize, patch.
Please run the case with the options already discussed and let us know the oputput.
Keyur
October 17, 2018 at 3:34 am
October 17, 2018 at 3:44 am
Keyur Kanade
Ansys EmployeeFor time step, you can calculate ((Vcell_min)1/3)/vel
And yes, the you are using correction option for patching.
Once patched, please cross check volume fraction contours and then only proceed with iterations.
Keyur
October 17, 2018 at 4:02 am
October 17, 2018 at 4:29 am
Keyur Kanade
Ansys EmployeeYes, 0.005 is ok.
I would say go with 0.002 for first few time steps and then increase it to 0.005.
Keyur
October 17, 2018 at 4:40 am
mozeer
SubscriberAlright thank you!
Regards
Ikhlass
October 17, 2018 at 4:41 am
Keyur Kanade
Ansys EmployeeWelcome!
Let us know how it goes.
Keyur
October 18, 2018 at 1:28 am
mozeer
SubscriberYes so Its finally converging, but there is something wrong somewhere since the results are really bad. Its actually not simulating what it should.
Ikhlass
October 18, 2018 at 1:44 am
Karthik R
AdministratorHello,
Could you explain a little bit more so we understand what's wrong with your results? Please provide the necessary plots.
Thank you.
Best Regards,
Karthik
October 18, 2018 at 2:05 am
October 18, 2018 at 10:41 am
Ansys EmployeeOK. Flow is pushed into the inner chamber from the inlet. It passes through the porous media and then (ideally) flows to the outlet. If the device is flooding then then the flow rate may be too high for the system.
October 18, 2018 at 12:49 pm
mozeer
Subscriberyes, but I am using the same flow rate with which I did the testing in the lab. And all dimensions of geometry are same to the real model.
October 18, 2018 at 1:17 pm
Ansys EmployeeHave you got plots of the inflow & outflow mass with time? I ask as it's quite possible flow will not be constant on the outlet so the balance may be better. For the lab model was the chamber half full of solid block and have you checked the porous resistance?
October 19, 2018 at 5:19 am
Keyur Kanade
Ansys EmployeeHi,
How many time steps you ran? Did it converge in every time step? If not, please increase no. of iterations per time step to 30 or 40.
Can you please give more details about results. Insert more images of contours.
Keyur
2706
2138
1355
1144
462
