December 8, 2022 at 3:00 pm
sami abdelmalak
Subscriberi have been gettng this message for almost a week now and i dont see any issue with the ports
i have deleted all the ports and reassigned thema nd still getting the same error
December 8, 2022 at 3:06 pm
sami abdelmalak
SubscriberPort refinement, process hf3d error: Waveport s is internal to solution domain and not fully backed with a PEC object.. Please contact Ansys technical support.
December 13, 2022 at 2:28 pm
Praneeth
Ansys EmployeeHi Sami,
Please note that the wave port is to be external to the model.
If you intend to use it inside of a model then it should have a PEC object. In the latest version of Ansys Electronics Desktop, the tool will prompt automatically during the port creation.
If you are new to Ansys HFSS then I suggest you to go through this video based course - Ansys HFSS Port Types - ANSYS Innovation Courses.
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2726
2146
1357
1150
462
