August 1, 2023 at 12:09 pm
Haoxiang Lu
SubscriberHi,
I am a starter of Lumerical and I am having problem about 3D FDTD simulation. The port (called input ) in my simulation takes too much memory as shown in the graph.
I lowered my frequency points to lower than 5, and I put my ports close to each other as possible, but the memory is still big. I need the port to get S-parameters. Is there any way to minimize the memory used by the port?
August 1, 2023 at 4:55 pm
Amrita Pati
Ansys EmployeeHi Haoxiang,
I have seen that sometimes the memory requirements for mode sources/ports are overestimated. I will ask you to run the simulation as it is if you’re able to. If not, you can try to:
- Make the mesh size coarser.
- Reduce the size of the port.
- If you are using a narrowband source and the field profiles do not change significantly over the wavelengths, then uncheck the frequency dependent profile in the port settings. This will calculate the mode only at central frequency.
Please let me know if you have any further questions.
Amrita
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7646
4466
2955
1427
1322
