August 21, 2019 at 3:31 am
bamdadslr
SubscriberHello everyone
I am doing a HFSS simulation which includes the overhead transmission line conductors. I want to put matched impedances at the end of each line to remove the reflections. Can I define a port at the end of each cylindrical conductor and terminate the port with a matched resistance (in the edit sources tab)? And if so, do I need to connect the conductor to the ground? -
September 4, 2019 at 4:10 pm
slouie
Ansys EmployeeYes, you will want to define a port at each end of the conductor - the ports will be defined between conductor and ground. If your solution type is DrivenTerminal, you may use Edit Sources to terminate one of the ports with a matched resistance value (you will need to toggle "Terminal Excitation Type" to Total Voltage in the Edit Sources window first).
- Maxwell, HFSS or Q3D?
- Error
2614
2088
1321
1108
459
