Possibilities with DEFINE_UDS_UNSTEADY in Fluent
    • MarkusP
      Dear community members,
      when having a look at Fluent's UDF DEFINE_UDS_UNSTEADY, I noticed that the description and example given in the documentation only uses a first-order accurate time discretization scheme and constant density.
      Is it possible to use also
      • a second-order accurate time discretization scheme, and/or
      • a non-constant density
      within this UDF?
      Thanks for your help!
      Best regards,
      Markus
      Looking in the 2020R1 doc I can't see any limitations on density or scalar discretisation. Check the transient section of the User's Guide as it'll be determined by the scalar and not the UDF.
    • DrAmine
      No limitations.
