June 22, 2018 at 10:58 am
cm1g14
SubscriberWhere solids have been copied (in SpaceClaim) or are part of a pattern (in Solidworks), Discovery Live has some unexpected behaviour. For some reason, some of the solids are not taken into account - and which solids are considered can change between solutions. If each solid is made independantly then the correct behaviour is seen. I presume this is not intended behaviour, but either way could this be changed?🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
June 22, 2018 at 12:15 pm
Naresh Patre
Ansys EmployeeHello cpjmcquillan
IÂ did a quick test case by creating a pattern of cylinders using Move command. I could see that the solid bodies were respected and flow was not passing through these patterned bodies. I am attaching the test case for your reference.
The objects in both files you shared have a very small thickness as compared to the overall dimensions of the enclosure. This could be the reason behind your observation. Please try increasing the thickness of the objects within the enclosure or reduce the enclosure size. Also, try running the model on higher graphics card with max fidelity.
You may also want to check out below post:
Discovery Live: "Thin" geometric features and relative GPU adjustments
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
June 22, 2018 at 12:44 pm
cm1g14
SubscriberNaresh Patre Ok, thanks
3862
2639
1859
1254
600
