June 29, 2023 at 11:45 am
Dmitry Zhuk
SubscriberHello,
I'm using the procedure from that page: https://simutechgroup.com/post-processing-apdl-models-inside-ansys-workbench/
It worked fine before but when tried to open 200 Gb .rst file it gives an error: An error occurred while copying result file to the solver files directory.
I don't have additional 200 Gb on my hard drive to get file copied and I don't really see the point of copying. I tried to move .rst file to ..\dp0\SYS-1\MECH before opening it in WB but error presists.Any help is appreciated
June 30, 2023 at 6:43 am
Aniket
Ansys EmployeeThis error most likely is about the space while reading the rst file, you may want to open a new SR with us if possible. An alternative approach to this one would be reading rst file using opensource pyAnsys products. One example can be found here:
Basic DPF-Core Usage with PyMAPDL — PyMAPDL (pyansys.com)
-Aniket
4484
2957
1435
1322
