Post processing: explode view of contour planes
    • Panagiotis Artemiou
      I am trying to post process some contours. I have channells inside of which is the fluid flow, and i want to present the velocity field in 3 different planes as shown in the image i am attaching.
      However in the scale of the model, these planes are too close to each other.
      Is there a way to move the planes a bit further away from each other for a better view? But maintain the velocity field of the original planes.
      Essentially, I want to move them apart just for presentation purposes.
      Thank you very much!
    • omkar.kulkarni
      The planes can be created only till the extent of the model. They can't be moved outside the boundaries of the model.
      If size of the model is big I would suggest you to scale the model under the Domain tab and then setup the case.
      I hope this helps.
      Thanks,
      Omkar Kulkarni
