November 7, 2023 at 8:53 am
murali
SubscriberThis is the displacement probe plot for the free end of a cantilever beam subject to an initial displacement of 5e-3 m. I did this as a 2 step analysis. I have two questions:
- How should I adjust the analysis settings so that I get the displacement 5e-3 at time 0 (as it is not possible to keep the step end time as 0?) ? Or is there some way to adjust the plot once the analysis is done?
- How do i get rid of the points on the curve so that I have a smooth curve?
Thanks In advance.
November 7, 2023 at 1:24 pm
Erik Kostson
Ansys EmployeeHi
Answer to both questions is: copy the data from the displacement probe, and paste into excel and change the values as needed so they start from when you want – when plotting there you can choose a curve with no dots at the plotted values (so line only graph, dots only etc.).
All the best
Erik
November 8, 2023 at 9:30 am
murali
SubscriberThanks you Erik.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1688
1478
