August 28, 2019 at 11:02 pm
Jonathanmosh2
SubscriberHi everybody,
I am working on a series of files with the same geometry but different external conditions.
I want to save my deformation contours so that all of them have the same visual characteristics such as the same size and location of the body in the display window, the same color bar range, font size, etc. ( if you have experience with STARCCM+, for example, you can copy the visual features of your desired contour and copy it to other contours to create figure that have similar setting.
How can do the same thing in the Workbench?
Thanks.
August 29, 2019 at 12:19 am
SubscriberRight mouse click on a Legend > Named Legends > New ... and give it a name.
Repeat but select Manage, pick the named legend then Export...
On another result, right mouse click, Manage > Import ...
This is how you create the same legend on multiple results.
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2688
2138
1355
1140
462
