Postprocessing commands after the model is solved
    • Samir Kadam
      I am adding postprocessing commands in Mechanical. Why executing post commands with model 'Solve' works fine. But if executing post commands separately after the model is solved, it fails?n
    • Rahul Kumbhar
      nGo to the 'Solution Information', select 'Post Output' to check the error messages. You might need to add FILE command at the start of the post commands to specify the data file where results to be found.nEg:nFILE, Fname, Ext, --nnFname:nFile name and directory path. The file name defaults to Jobname.nnExtnFilename extension.nIf Fname is blank, the extension defaults to RST (for structural, fluid, or coupled-field analyses), to RTH (for thermal or electrical analyses), or to RMG (for magnetic analyses). For postprocessing contact results corresponding to the initial contact state in POST1, use the RCN extension.n
