October 29, 2018 at 6:32 am
Jamessmp23
SubscriberHello all,
I'm curious about the geometry display on the postprocessing section, fluent software. Here is the image on the postprocessing
On the spaceclaim I draw the cylindrical shape for the draft tube geometry but on the post processing section I saw it like a prism shape,
so my question is, does the simulation calculate as the cylindrical shape ? why it appear as the prism shape ?
Thank you all,
James
October 29, 2018 at 6:52 am
Keyur Kanade
Ansys EmployeeHello,
You might have defined some boundary zone in Fluent at that location and that is why you see those prism shape faces.
OR
You might have missed meshing at that location.
Please cross check your boundary zones in meshing and in Fluent.
Keyur
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
October 29, 2018 at 8:08 am
Jamessmp23
SubscriberHi,
Thank you for replying. I already identified the draft tube geometry and name selected the draft tube for mesh sizing (1e-2), for the boundary I set it as stationary wall.
Any recommendation ? I still don't know why it appear like this and does it calculate as the cylindrical shape tube or prism shape tube ?
Best,
James
October 29, 2018 at 8:37 am
Keyur Kanade
Ansys EmployeeHi,
can you please insert the image of boundary zone names you can see in Fluent.
Keyur
October 29, 2018 at 10:20 am
Jamessmp23
SubscriberHi,
sorry for late reply I have been waiting for the calculation.
I had tried to mesh sizing again with more precisely, for now I'm able to get the cylindrical draft tube on the post processing.
Here is my set up on wall stationary for the draft tube. Another curious for my draft tube interior boundary, fluent auto set as interior do I need to change it in to wall ?
Thank you,
James
October 30, 2018 at 3:30 am
Keyur Kanade
Good that you can get that as cylindrical.
If you have fluid on both side of a boundary zone, fluent will set it as interior. If you want you can change it to wall.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2138
1355
1140
462
