Postprocessor Error
    • GeorgeAerospace
      Hi dears,
      I am facing an error while opening the result file in Mechanical. It says that
      "Error Occurred when the post-processor attempted to load a specific result''
      How Can I solve this Problem?
      Thanks
    • peteroznewman
      Delete the Frequency Response and recreate the output you want.
    • GeorgeAerospace
      I have already deleted the output, and the solution was completed successfully, but when I generate the frequency response, it gives me the same message!
    • peteroznewman
      Please show the Details of the Frequency Response output.
    • GeorgeAerospace
    • peteroznewman
      Under Analysis Settings, please show the Output Requests in the Detail window.
    • GeorgeAerospace
    • GeorgeAerospace
      I noticed that the error occurred only when I want to generate the FRF using Base excitation only, otherwise, no error occurred as shown below!
      So, How can I fix this error??
