November 29, 2020 at 1:33 pm
Faiza
SubscriberMon ?tude concerne la mod?lisation d'une poutre en b?ton arm? soumise ? une flexion en 4 points.nMon probl?me est d'?tudier l'endommagement de la poutre en utilisant le mod?le d'endommagement du b?ton comme celui de Mazars.nJ'utilise le programme Mechanical APDL d'ANSYS, pour cela je voulais savoir comment int?grer le mod?le d'endommagement dans le programme APDL ?nSVP aider moi si quelqu'un connais l'astuce ou d?j? travailler sur une ?tude plus ou moins similaire.nnJe vous remercie d'avance .nnCordialement ,nnFaizan -
November 29, 2020 at 3:25 pm
SubscriberGoogle Translate on the above post.nCould you help or guide me on the implantation of a concrete damage model for examplenMy study relates to the modeling of a reinforced concrete beam subjected to a bending in 4 points.nMy problem is to study the damage of the beam using the concrete damage model like that of Mazars.nI am using ANSYS Mechanical APDL program, for that I wanted to know how to integrate the damage model into the APDL program?nPlease help me if anyone knows the trick or is already working on a more or less similar study.nI thank you in advance .nRegards ,nFaizanBelow I added a link I found that describes Mazars Damage model:nhttps://mooseframework.inl.gov/blackbear/source/materials/MazarsDamage.htmln
- The topic ‘Pourriez-vous m’aider ou guider sur l’implantation d’un modèle d’endommagement de béton par exemple’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1688
1478
