Power dissipation
    • Srinivasagam Venkataramanan
      Hello Friends,
      I am working on the simulation of a PCB board with ICs and a DC-DC converter. I have defined power dissipation(Watts) values for each chip and DC converter. PCB is placed inside an enclosure that acts as a Heat sink. I am interested in understanding how much power dissipated to the surroundings and on the frame. I have run steady state thermal analysis to determine the temperature rise. how to calculate power dissipation?
      Thanks,
      Srini
    • Pdev
      To calculate the power dissipation, you may select the "Heatflow" option for the particular geometry in the summary report.
      Thank you,
      Pdev
