Power outage while simulating fluid flow
    • akin3rd
      I have a bad battery that I have not gotten around to replacing yet and as such, my Laptop goes off quite often.
      This has happened while fluent is running and while I have been able to continue the simulations from the last iterations when this occurs (usually) I am curious to know the effect of an abrupt power outage while fluent is running if one exists at all?
      Thanks
    • DrAmine
      Always allows Fluent to store case and data files so that you do not need to restart from the beginning. Effects of power outage on Fluent are the same for any different applications? What do you expect?
