July 30, 2019 at 1:12 pm
vipinmundro
SubscriberI am running a Spray combustion in fluent using DPM with an upstream pressure of 13 bar and downstream pressure 0.6 atm, i want to know whether the pressure build in this analysis is slow or not? After 1000 iterations, am getting pressure distribution with max as 0.8 bar, never reached 13 bar. I need some urgent help on this?
July 30, 2019 at 1:45 pm
Ansys EmployeeWhy do you expect to see 13 bar in the system? Some images may help, as would an explanation of what you're modelling.
August 1, 2019 at 10:36 am
August 1, 2019 at 11:08 am
Ansys EmployeeAnd the flow is 0.6bar when leaving the above domain? Or exhausts into a zone kept at 0.6 bar?
August 1, 2019 at 12:06 pm
vipinmundro
Subscriberflow is leaving at 0.6 bar
August 1, 2019 at 1:25 pm
Ansys EmployeeSo, the system has a 12.4bar pressure loss?
August 2, 2019 at 4:52 am
vipinmundro
Subscriberyeah!
August 2, 2019 at 10:48 am
Ansys EmployeeCheck your inlet boundary conditions, but also your assumption on the unit operating conditions: 12.4bar is a huge loss in a system when you have to pressurise fuel & oxidant first.
August 2, 2019 at 1:23 pm
vipinmundro
Subscriberyea i am injecting fuel & oxidizer at this pressures
August 2, 2019 at 2:25 pm
Ansys EmployeeHow stable is it?
2706
2146
1357
1144
462
