June 11, 2020 at 8:54 am
Bimark9
Subscriberhow does the maximum number of cycles and steps affect my solution
June 11, 2020 at 5:17 pm
Karthik R
AdministratorHello,
Which tool are you using and what it the scope behind your question?
Thanks
Karthik
June 12, 2020 at 9:02 am
Bimark9
Subscriberam using Ansys WB R19.2
I wanted to know if the processing time or the solve time depends on the number of cycles and steps
thank you
June 12, 2020 at 9:04 am
Bimark9
Subscriberin addition to that am running an explicit study
June 15, 2020 at 2:39 pm
SaiD
Ansys EmployeeHi,
An explicit analysis takes small steps forward in time, with each step taken forward being called the cycle. The size of the cycle is determined by the CFL condition and is dependent on the material properties and mesh density. The Maximum Number of Cycles is the largest number of these tiny steps that an analysis can take. E.g. If the analysis End Time is 1e-7 and it is determined by the solver that the step size (or time increment) to be used is 1e-10. That means it needs 1e-7/1e-10 = 1000 cycles. Now if the Maximum Number of Cycles is set to 100, the solver will stop after 100 cycles and hence the simulation will not be completed.
It is recommended to define a large number for Maximum Number of Cycles so that the simulation runs till the defined End Time.
A Step is a small interval of time in which some new load is applied or some condition changes. E.g. If you have a case where a force of 100N is applied at t=0 sand at t=0.01 s an additional load of 200 N is applied. Then you would have at least 2 steps, first step from 0 to 0.01 s and second step from 0.01 s to analysis end time.
You can read more about it here:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/exd_ag/ds_explicit_dyn_settings.html%23ds_exd_settings_step
Hope this helps,
Sai
3806
2587
1843
1244
600
