Photonics
Photonics
Precise volume mesh
    • Iman Alhamdan
      Hi
      I wonder where I can find information about the precise volume mesh and it's refinement number, difference between using a volume mesh and a conformal mesh
    • Guilin Sun
      It is in this page https://optics.ansys.com/hc/en-us/articles/360034382614
      This method is suggested to be used for photonic inverse design, not for every simulation, as it uses some kind of average method.
      I strongly suggest you to use conformal meshing methods:
      https://optics.ansys.com/hc/en-us/articles/360034382614-Selecting-the-best-mesh-refinement-option-in-the-FDTD-simulation-object
      To reduece the difference, you may need to use finer mesh.
    • Iman Alhamdan
      Yes
      I have seen this recommendation but I just want to understand the math and science behind it. Is it explained anywhere ( specifically for metasurfaces)
      Thank you
    • Guilin Sun
      Unfortunately no. I believe it is simply the averaged refractive index inside the mesh volume. The  photonic inverse design example uses fixed value of refractive index, not dispersive model.
Viewing 3 reply threads
