October 2, 2018 at 12:54 pm
October 3, 2018 at 12:19 am
klu
Ansys EmployeeHi,
Do you have any experimental data or theoretic estimation for the flame propagation based on the model conditions? Would you please provide more details why you think the flame is propagating too far? Thanks.
October 3, 2018 at 3:24 pm
krany3
Subscriber -
October 6, 2018 at 12:18 am
klu
Ansys EmployeeHi,
Although the conditions are the same, how about the mesh density and quality, convergence, etc? Would you think that it is an apple-to-apple comparison? Please also compare the results for example the turbulence variables, reaction rate, etc. so that we may better analyze the difference. In addition, would you run a URANS model in case the flame has high unsteadiness?
October 6, 2018 at 7:37 pm
DrAmine
Ansys EmployeeValuable suggestions.
October 6, 2018 at 8:41 pm
krany3
SubscriberThank you. The meshes are different. I don't have anything to compare with, except the temperature contour. Maybe, I'll try the uRANS and will see how it's varying.
October 16, 2018 at 3:53 am
krany3
SubscriberI tried with uRANS. It didn't give me the swirling flame. What could be the reason?
Thanks
October 16, 2018 at 7:26 pm
DrAmine
Ansys EmployeeFor swirling flames and generally swirling flows two equation models or any boussinesq approach eddy viscosity based model will behave wrong. Flow anistropy and secondary flows are well capture by second momemts of closure RANS models as well as scale resolving methods. Please post your model settings deployed boundaries and material properties.
October 16, 2018 at 7:27 pm
DrAmine
Ansys EmployeeAlso moving the thread to Fluid dynamics category.
October 16, 2018 at 9:42 pm
krany3
SubscriberModel Settings:
-For turbulence modeling
realizable k-epsilon model with standard wall functions and default model constants
-For combustion
Species transport with volumetric reactions. 2 step chemical mechanism of CH4-Air was used.
Turbulence-chemistry interaction was modeled using finite-rate/eddy dissipation model
Material Properties:
CH4-air mixture properties:
Density - calculated using incompressible ideal gas equation
Specific heat - using mixing law
Thermal conductivity -0.0454 w/m-K
Viscosity - 1.76 e-05 kg/m-s
Diffusivity - 2.88e-05 m2/s
Boundary Conditions:
INLET
mass flow rate - 2.0579 g/s
turbulent intensity - 5%
turbulent viscosity ratio - 10
temperature - 300 K
species mass fractions - CH4-0.0376, O2 - 0.2239, rest is N2
OUTLET
temperature - 300 K
species mass fractions - O2-0.0739, CO2-0.1032, H2O - 0.0844
Chamber walls were set at a temperature of 600 K
For the pressure-velocity coupling SIMPLE algorithm was used and gradient method used was least squares cell based. All the discretizations were modeled using 2nd order upwind scheme
Default under-relaxation factors were used except for species and energy, which are 0.8
October 17, 2018 at 12:59 pm
DrAmine
Ansys EmployeeAnd do you know what has been used for LES run? I guess a high-end combustion model like EDC with detailed mechanisms. As LES is always transient I assume the picture you posted has been time-averaged over a certain time intervall. If you want to make a comparison you need to use the same methods or at least use the same combustion model and boundary conditions.
October 17, 2018 at 3:26 pm
krany3
SubscriberYes Amine. The posted picture was the time-averaged temperature. For LES, they used thickened flame model for modeling turbulence-chemistry interaction. I'm confused on which model to be used. Is it EDC or the flamelet generated manifold (FGM)?
Thanks
October 19, 2018 at 2:31 pm
krany3
SubscriberHello Amine, which model in Fluent is considered as the thickened flame model?
2688
2138
1351
1136
462
