February 1, 2021 at 1:34 pm
morrowinter
Subscriberhello,ni would like to check the error using the prerr command (on one element or whole MEF if possible).nHow can i do such thing ?nThank you,nBest regardsn -
February 2, 2021 at 9:07 am
Ashish Khemka
Ansys EmployeennIn the postprocessor issue the prerr command. If you want it for one element then select the element and then issue the comand. Refer to the example below:nnnRegards,nAshish KhemkannAccessing Ansys Help - https://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-helpn
3389
2471
1310
1022
