August 20, 2019 at 9:43 am
Prasadpk15
SubscriberI want to perform the thermal simulations over the design of energy efficient pressure cooker that I developed. I have following doubts -
1. Whether I should select the Thermal transient or Fluent for this simulation?
2. I also want to compare the energy required for boiling the water in cases of energy efficient pressure cooker and normal pressure cooker. So, what should I select as the need conditions of the simulations?
August 20, 2019 at 10:27 am
Ansys EmployeeWhat level of detail do you need? Ie do you need to consider fluid convection?
How would you measure the efficiency in an experiment? Time to heat up, energy supplied v temperature gained etc? We can monitor most things, you need to define what you want from the model.
August 22, 2019 at 5:14 am
Prasadpk15
SubscriberI need simulations in detail.
I am considering convection at every solid - fluid interfaces. Such as, convective heat transfer between hot water inside the pressure cooker and inner walls of the pressure cooker. Also, convective heat transfer between outside air and outer walls of the pressure cooker.
I want to measure efficiency with respect to energy required to boil the given amount of water inside pressure cooker from room temperature. Since heat flux supplied to the pressure cooker is constant with respect to time, time required and energy required would be directly proportional.
So, I want either energy required or time required to achieve final water boiling condition in both traditional and energy efficient cooker design that I will be proposing.
August 23, 2019 at 3:06 am
Prasadpk15
SubscriberPlease reply for the about querry
August 28, 2019 at 12:50 pm
Ansys EmployeeOK, so you will need a CFD calculation. I would suggest reading up on buoyant flow and conjugate heat transfer.
October 10, 2019 at 4:20 am
Prasadpk15
SubscriberWhile performing CFD simulation of boiling water inside closed vessel do I need to use k-epsilon model or laminar model?
Also, Should I mention specific operational density or not??
October 11, 2019 at 12:11 pm
Ansys EmployeeIs the flow turbulent?
2524
2066
1279
1096
457
