Tagged: fluent, postprocessing, result-visualization, static-pressure
March 15, 2022 at 11:00 am
Ines_
SubscriberHi everyone!
I am performing fluid simulations in Fluent and I am getting the pressure in the fluid wall. Part of this wall is inmersed in the fluid and I am interested in getting the pressure difference between the two sides of it. Is there any way to select these two surfaces and getting the pressure difference?
Thank you so much in advance,
Inés
March 15, 2022 at 12:43 pmKarthik R
AdministratorHello:
You can create a solid wall (2D rectangle or 3D block). Once you have this, you should be able to select the two edges (in 2D) or surfaces (in 3D) and estimate your pressure difference.
Karthik
March 15, 2022 at 2:47 pmInes_
Subscriberthanks for your answer! What do you mean by creating a solid wall? with which tool can I do that? Also, in what part of the process should I do it (preprocessing (SpaceClaim) or postprocessing (Fluent))?
Thanks again In├®s
PD: my model is 3D
March 15, 2022 at 4:57 pmDrAmine
Ansys EmployeeCan you add a screenshot of what you want to do? Are the walls two different surfaces?
2616
2098
1323
1108
461
