Pressure Drop Computed is Too Small
    • cwl6750084
      Hello, nI am simulating high pressure (~3.5 MPa) vapour flow in a straight pipe of 12 m in Fluent. The known mass flow rate is 3 kg/s. The simulation was setup and however, the resulting pressure drop from inlet to outlet is less than 500 Pa. This pressure drop across the pipe seems way too small and incorrect. I wonder if anyone can shed some ideas on what could have been wrong. I checked the settings of the model and could not find any mistakes (as far as I can tell). Thanks. n
      Forum Moderator
      What material properties and boundary conditions are you using? How well resolved is the mesh?n
    • cwl6750084
      For liquid water, I used polynomials curve fits based on the steam table. For water vapour, the density was assumed ideal gas, other properties were polynomial curve fits from steam table data. The boundary conditions are pressure inlet and pressure outlet with temperature being set at the saturation temperature of the corresponding pressure. We did a mesh-independent study by making the mesh twice and four times as dense, the end flow parameters distributions are the same.nnThanks.n
      Forum Moderator
      Are you adding water or steam at the inlet? Which multiphase model? n
    • cwl6750084
      The VOF model with 99.5% volume fraction for steam at the inlet.n
    • cwl6750084
      By the way, the turbulence model was the k-epsilon model with enhanced wall treatment.n
    • cwl6750084
      If I switch to the standard wall function, the pressure drop is much higher. Does this imply the choice of wall function was incorrect?n
    • DrAmine
      Vof model is wrong. Either mixture or Eulerian should be used. If no stratification you might even use DPM. Are you expecting mass transfer?n
    • DrAmine
      Also if fou assume single phase of vapor does hagen poieusille pressure drop estimation match?Are you getting the right mass flux? What do you know at inlet?n
    • cwl6750084
      Flow is probably turbulent at some point down stream. I thought hagen poieusille pressure drop estimation match assumes laminar flows. Yes, the inlet fluid is 99.9% by vol steam but we expect a little of it be condensed.nnThe computed mass flow rate is correct and we are give the inlet pressure and temperature.n
      Forum Moderator
      For VOF the inlet boundary needs to be 100% one phase or the other. Move the conditions to be slightly above saturation and see if that helps. For the outlet you may need a drain boundary to let the water out. nBut for condensation type modelling you want to listen to Arrayn
    • DrAmine
      VOF model is not correct! If you do not expect any mass transfer and no stratification of droplet you might even use DPM Model.n
    • cwl6750084
      Thanks your advises. Let me try it with the mixture model. The inlet is about 99.5% by volume of steam and it is expected ~95% by volume at the outlet of the pipe. nWhat does it mean by a drain boundary?n
      Forum Moderator
      With VOF some boundaries have all of one (or another) phase enter or leave the domain. It's sometimes then necessary to add a drain to get small amounts of the other phase out of the domain. As you're looking at a tiny fraction of second phase the DPM model is possibly better suited to this; Eulerian or Mixture may be another option. n
    • cwl6750084
      I changed to the mixture model and it actually increased the pressure drop, however, it is till not large enough until I changed to the scalable wall function and increased the wall roughness.nnI have another question, when I use the coupling with volume fraction or the n-phase volume fraction equation under PV coupling, I could got substantially different results. I am wondering when I should activate the option. Sometimes, it does not seem to have a huge effect and yet other times, such as the one below, using the coupling with volume fraction option gives substantially different results. I tried checking this in the manual but could not find the relevant section.nnThanks a lot.nnn
      Forum Moderator
      How well converged were the two solutions? n
    • cwl6750084
      The residuals were all in the order of 10^-3 to 10^-6 range for all variables except the energy equation, which is 3 orders of magnitude below other variables.nActually, when I include slip velocity in the mixture model, the problem went away.nIs there a general rule on when should I be using the Coupling with Volume Fraction option?n
Viewing 16 reply threads
  • The topic ‘Pressure Drop Computed is Too Small’ is closed to new replies.
