Discovery Import
Discovery Import
Pressure drop in a cooling line
    • andras.eberfalvi
      Dear Team, Let's say that I have a closed cooling loop. Is it possible to simulate the resistantance/ pressure drop of the pipe? I know the minimum flow rate I need (x l/min), so the inlet velocity can be calculated (by knowing the inlet surface).   Thanks for the help.
    • andras.eberfalvi
      I was also trying to get the flow. Knowing that the max pressure drop the water pump we have can handle is 3 bar.
    • andras.eberfalvi
      Sorry I forgot to mention that the task is in discovery live
      • Naresh Patre
        Hello aeberfal
        Modeling a closed loop is currently not possible in Discovery Live.
        As a workaround, if you know mass flow rate by pump, you can only model the red portion of the pipe with mass flow rate as inlet boundary condition and 0 pressure at outlet. You can then measure pressure at inlet to see the pressure drop across red part.
      • andras.eberfalvi
        Hi Naresh Patre ,
        Thanks for the answer :). Have a nice day.
