November 30, 2022 at 9:07 pm
KUMAR Kundan
SubscriberHi all, I am trying to calculate pressure drop for the attached image of a cell cooling plate. The only problem is I could not understand how to calculate average absolute pressure at inlet and outlet for this model. I am open to your ideas, please share.
I am using fluent for analysis, the flow is laminar, and the K-Omega solver is used for the calculation.
December 1, 2022 at 5:22 am
Nikhil Narale
Ansys EmployeeHello,
Fluent always uses the gauge pressure. However, if you set the Operating Pressure to zero, your gauge pressure becomes the same as the absolute pressure, which can be determined using reports. Caution needs to be taken while setting operating pressure to zero. Check this for more information: ANSYS FLUENT 12.0 User's Guide - 8.14.3 Setting the Operating Pressure (enea.it)
Thanks,
Nikhil
December 1, 2022 at 5:35 am
Nikhil Narale
Ansys Employee-
December 1, 2022 at 11:17 am
KUMAR Kundan
SubscriberThank you very much Nikhil. I will do the same.
2620
2098
1323
1110
461
