Pressure Drop in Fluent
    • TechBoy
      How to calculate pressure drop for a microchannel heat exchanger in Fluent ?n
      Look at the pressure on the inlet and outlet and find the difference? n
    • TechBoy
      1) It should be pressure from Reports > Surface Integrals ORnReports > Volume Integrals ?n2) Which pressure to be selected: Static, Dynamic, Absolute or Total Pressure ?n
      If you read the section defining what each of those are what would you choose? n
    • TechBoy
      I don't understand Sir.n
      We define all of the post processing variables in the manual. Having read what each of the pressure terms means, why do you think you should choose one of them? What would you report in an experiment? n
Viewing 5 reply threads
