Pressure Drop in Fluent Axisymmetric Turbulent Pipe Model is 2X Darcy-Weisbach Prediction
    • Rick28
      I am working on a Fluent model of turbulent flow in a pipe. Data for the model follows:
      0.2 m diameter, 20 m length
      water fluid
      inlet velocity: 0.1 m/s
      outlet pressure: 0 Pa
      Axisymmetric Geometry with 500 x 30 graded mesh
      k-epsilon model
      I have attached plots reflecting
    • Rick28
      Reran case with "Enhanced Wall Function" and the results are now very close to the analytical solution. Sorry for bothering the forum as I found a helpful discussion related to this from May 2020.
