Pressure drop
    • moloud.mardani
      HI every body,
      How can I find pressure drop in fluent?
    • peteroznewman
      Plot the pressure. The difference in pressure between any two points is a pressure drop. If you want a more detailed answer, you need to provide more details for a specific model.
    • moloud.mardani
      Thank you very much
      Actually my pressure in inlet is 1.2 bar. Where should I enter this pressure? in inlet BC or operating condition window? Because it really change the result.
    • Raef.Kobeissi
      you need to enter it as an inlet BC. You need to assign Inlet Pressure for your inlet BC.
      Cheers
Viewing 3 reply threads
