July 17, 2019 at 1:51 pm
info
SubscriberHello,
I would like to extract the a pressure force on a surface based on a reference frame, but I guess it is not possible, i.e. the x/y/z components of the 'PressureForce' are always in the direction of the model global coordinate system.
In the attached example I'd like to extract the resulting force on the surface along the X-direction of the reference frame shown on the attached image (that is not the global/model one).
Please verify!
Csaba
July 18, 2019 at 6:54 am
Naresh Patre
Ansys EmployeeHello steelxpert
I will check it and get back to you.
July 23, 2019 at 11:53 am
info
SubscriberHi Naresh Patre
Can you please update me on this matter?
Csaba
July 24, 2019 at 8:14 am
Naresh Patre
There is no direct option to select a local reference frame while extracting pressure force. However, I am checking if it is possible to achieve the same via expressions and will let you know.
July 24, 2019 at 11:02 am
info
SubscriberHello Naresh Patre
Thank you, that would be great.
July 25, 2019 at 10:04 am
Naresh Patre
I see that the reference frame is aligned along the geometry face. So, won't the variable "PressureForce.mag" (Pressure Force Magnitude) give you the resultant force normal to the selected geometry faces?
You can also use below expression which eventually gives you the resultant pressure force (Pressure Force Magnitude)
sqrt((pow(PressureForce.x,2)) + (pow(PressureForce.y,2)))
July 29, 2019 at 7:01 pm
info
Subscriberhello Naresh Patre
Thank you for your answer.
Basically, my original question concerned more the possibility of having the Pressure:force components aligned to a user-defined Reference Frame rather than concerning the solution for that specific problem/geometry.
steelxpert
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3720
2570
1777
1236
594
