TAGGED: 2D, explicit-dynamics, ls-dyna, mechanical-apdl, structural-mechanics
June 3, 2021 at 9:25 am
LCP
SubscriberHello,
I am simulating a hyperelastic stick with a pressure load exerted on the side of the stick. I assumed this load would be applied on the normal (just like in the first picture) for the entire simulation, but it seems that it is exerted in the x-direction instead. I have checked this using ANSYS Mechanical, where I know for certain the pressure is exerted on the normal axis. The difference between the two results is shown in the second picture. When changing the pressure load to x-direction in ANSYS Mechanical, the result resembles the LS-DYNA result closely. So how do I check how the pressure load is exerted in LS-DYNA, and how do I make sure it is exerted in the normal direction?
Kind regards,
June 11, 2021 at 12:15 pm
Akshay Maniyar
Can you share some more details about the model? Is it a shell mesh?
Which card you are using to apply load?
regards amaniyar
June 16, 2021 at 12:08 pm
LCP
For the LS-DYNA mesh: I am using shell elements (8SECTION_SHELL -> option plane strain). This means I am essentially modeling 2D solid elements. I create create a segment set by selecting the edge and clicking propagate. Then, I apply the load via *LOAD_SEGMENT_ID. I also applied *HOURGLASS type 7. I do not know if this is necessary, though.
For the ANSYS Mechanical mesh: I am using PLANE182 elements with a plane strain assumption.
I already found out that LS-DYNA does exert the pressure on the normal axis, since the tip of the valve cannot be lower than the middle of the valve if it was exerted in the x-direction. The weird thing is, when I run the simulations in ANSYS Mechanical 2021R1 the displacement does coincide with LS-DYNA, but when I use ANSYS Mechanical R19.2, the deformation is much larger than LS-DYNA. Do you know why this is the case?
June 16, 2021 at 2:47 pm
Akshay Maniyar
Ansys EmployeeHi @LCP I am not sure exactly why you are getting difference in the results for 19.2 and 2020R1. Can you create a new post for this query as the original question was for LS-Dyna. May be some structures expert can answer this. I will also check mean while.
regards amaniyar
- The topic ‘Pressure load is exerted in the x-direction instead of on the normal axis (LS-DYNA) ?’ is closed to new replies.
- LS-DYNA Installation Issues with Student Workbench 2024 R2
- Cross-coupled stiffness elements in LS-DYNA
- Initial Velocity Generation
- MAT072R3- concrete damage rel3 validation
- Initial Stress Shell Application and HistVarCosine in LS-DYNA
- shape memory alloy material in LS-DYNA
- *** Error 40058 (SOL+58) retractor 1000002:convergence failure at time1.01E+02
- LS-Dyna, Negative volume problem.
- Mohr_Coulomb material model (MAT_173)
- Fluid-structure interaction coupling
1967
886
599
591
366
© 2025 Copyright ANSYS, Inc. All rights reserved.
