Discovery Import
Discovery Import
Pressure loss
    • fuyu-m
      I want to know the pressure loss in the pipe flow.
      I think that the pressure loss in the pipe flow will be the total pressure at the pipe inlet minus the total pressure at the pipe outlet.
      ●question 1
      Is "Pressure" handled in Discovery Live the total pressure or the static pressure?
      ●Question 2
      Is it possible to check "total pressure" or "dynamic pressure" when "Pressure" handled in Discovery Live is static pressure?
      I expect to receive answers.
      Thank you.
    • Brian Bueno
      Wintercat
      I have inquired with the development team and will update you as soon as I've had a response
      • fuyu-m
        BBueno_ANSYS  , Thank you very much.
        I appreciate being able to give you an answer.
      • Brian Bueno
        Wintercat
        Discovery Live uses static pressure or gauge pressure. You cannot check absolute pressure as it has not been defined in the simulation.
      • fuyu-m
        BBueno_ANSYS , Thank you for your response.
        Pressure loss is very important in flow in pipes. So I expect Discovery Live to be able to see pressure loss.
