October 25, 2018 at 5:52 pm
October 26, 2018 at 3:55 am
SubscriberI see you have a 5 kg mass impacting a skull at 6 m/s aligned with the center of mass, so this is a transient dynamics problem.
I see the three pressure measurement points: A, B, C. Is this the pressure inside the skull near soft brain tissue? I assume you want a pressure-time history plot that shows the pressure wave from the impact. Or is it the stress in the bone itself, since stress has the units of pressure?
ANSYS can calculate pressure due to impact. Please clarify what exactly you want to calculate and more about the material the 5 kg mass is composed of. If it is a 5 kg silicone rubber block, which has low stiffness, it will exhibit large deformation on impact and the pressure wave will be different than if it is a 5 kg steel block.
October 26, 2018 at 4:12 am
eman
SubscriberIn explicit dynamic I want to measure the pressure on specific point like the first pic in the previous post
The 5 kg is stanless steel
I want to know the affect on skull when the the 5kg impact to it at specific point
And how can I do the grid in the front skull ? -
October 26, 2018 at 11:57 am
SubscriberDo you have geometry for a skull? If so, you open that geometry in SpaceClaim. You can split the geometry to create a Vertex at points A, B and C. Do you have material properties for bone? You enter that in Engineering Data.
After the geometry is attached, you open the Model item where the meshing to form the grid of nodes and elements are done.
October 26, 2018 at 12:09 pm
October 26, 2018 at 2:29 pm
SubscriberOn the Design Tab, Add a two planes that intersect at the point where you want to measure pressure. Then Split Body is one of the tools. Click on SYS and make sure in the Properties that Share Topology is set to Share instead of None. This will create a vertex on the surface of the skull-bone.
I assume the geometry is hollow and has a wall thickness. You can't do this with a solid filled skull shape.
Are you trying to simulate a hollow, dry, skull-bone or a flesh covered, wet, brain-filled skull?
October 26, 2018 at 4:33 pm
eman
Subscriberi try to simulate just skull-bone
October 26, 2018 at 8:19 pm
SubscriberWere you successful using the Split Body?
October 29, 2018 at 5:15 am
eman
SubscriberHow can I do refine path on ansys ?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1285
1096
459
