LS Dyna
LS Dyna
Pressure on line body in explicit dynamics
    • arunprabhat12
       I have to apply pressure on truss line body members. Pressure is time varying blast triangular load. When i am applying line pressure through tabular instead of magnitude there is some error. But when using line pressure using magnitude then there is no error. So how can i apply a time varying pressure on line body?
    • Sandeep Medikonda
      Hi Arun,
        Please see this post on how to define an expression for pressure based on time.
      Sandeep
    • arunprabhat12
      Thanks Sir
      But when i am applying line pressure through tabular data, an error "Could not transfer loads and constraints to the solver" occurs.
      But for pressure on surface body it is not showing any error
    • Sandeep Medikonda
      Arun, Can you explain with inline pictures as to what you are doing?
    • arunprabhat12
      this is a normal cantilever beam with any random c/sec.
      I am applying a time varying line pressure in explicit dynamics module.
      In the solution, this error appears
    • arunprabhat12
      But in the static structural module this type error is not shown in applying line pressure
    • Sandeep Medikonda
      Arun,
      Looks like only the constant load is not supported for Explicit Dynamics. This is from the manual:
      Loading Data Definition : Enter loading data using one of the following options.
      Constant: Supported.
      This is the only option supported for Explicit Dynamics.
      Sandeep
    • arunprabhat12
      Thanks Sir I have checked the manual and it is written that tabular data is not supported for acceleration and line pressure in Explicit Dynamics.
    • arunprabhat12
      If I do the analysis of bridge under blast in Autodyn solver instead of work bench, will that be much helpful?
    • Sandeep Medikonda
      Hi arun,
      Yes, tabular data is supported for displacement, velocity, force, pressure BC. But not for acceleration, even in Autodyn GUI.
      Sandeep
Viewing 9 reply threads
