June 28, 2019 at 8:11 am
jazi1212
SubscriberHello,
I am using Multiphase euler model along with Population balance model for my case. In my case there is no backflow but when i define pressure outlet boundary conditions, it asks me for a backflow volume fraction and also asks for turbulence case to be defined in terms of intensity and dissipation rate.
What are the values i should put or options i should consider to make the case understood that there is no backflow of any case.
June 28, 2019 at 9:59 am
Ansys EmployeeThey're needed incase flow enters the domain from the outlet. It's probably OK to set the back flow as primary phase only and turbulence based on the boundary size etc: how did you set it for the inlet?
June 28, 2019 at 10:03 am
jazi1212
Subscriberi have a velocity inlet so i put volume fraction for droplets 1 and provided separate velocities for inlet of air and droplets. However i know for a fact that there will be no backflow in my case. I think i read it somewhere that even if no backflow is expected still set realistic values of backflows at the outlet.
June 28, 2019 at 1:55 pm
DrAmine
Ansys EmployeeBackflow quantities are required whenever therer will be a numerical recirculation happening or a physical re-entrainment from outside.
Example: bubble rising in a tank filled with half air half water and the top boundary is atmospheric pressure boundary.
June 28, 2019 at 1:59 pm
jazi1212
Subscriberair as primary flow
water droplets as secondary flow
case is horizontal annular pipe
eulerian multiphase model
for pressure outlet, what do you suggest either i take volume fraction of air=1 or droplets=1?
In real scenario, i know that there is no backflow of air in my case. droplets wont be coming back from outlet but maybe droplets circulate and fall down on lower wall of pipe.
July 1, 2019 at 4:01 pm
Ansys EmployeeIf there are no droplets coming back in then setting air as vol frac of 1 makes sense. It's entirely down to the model so we can't really advise without all of the information. Run the model and see what happens.
3780
2587
1837
1244
600
