Pressure pulsation in Fluent
    • javat33489
      Hello colleagues.
      I am researching pressure pulsation in Fluent.
      DES turbulence model.
      I need to identify the amplitudes of pressure fluctuations, so that I can then decompose these data using the Fourier method and use them in harmonic analysis.
      By choosing different substep time sizes, I have different oscillation amplitudes.
      In this regard, I have several questions.
      1. Can I track the pressure amplitudes at the outlet of the product using the AreaAve(TotalPressure) graph? Or maybe look at the AbsolutePressure graphs or the StaticPressure on the outlet?
      2. I have selected a measurement point, but the graph does not work:
      3. I did some research with different time substeps, how do I choose the right one to take amplitudes from there for further solution? Here are the screenshots:Number steps 2000, time step 5e-5
      see the rest in the next post>>>
    • javat33489
      Number steps 2000, time step 0.005
      Number steps 2000, time step 0.1
    • javat33489
      Number steps 2000, time step 0.5
      Number steps 2000, time step 1
      Number steps 200, time step 0.2
