Pressure shock calculation in transient
    • javat33489
      Hi all.
      I do a shock calculation in transient analysis. The initial data are as follows, the cylinder moves towards the steel sheet. There is no initial speed, but there is pressure on the cylinder, which is 35 MPa. I simulate that during operation the plug on the product came off and flew into the protective fence.
      1. Is it possible to set the initial pressure as the initial speed? There is no such thing in the program.
      2. Is it possible to find the initial speed from the pressure?
      If I set the pressure on the cylinder, then the calculation ends with an error.
      In the settings I also chose impact:
    • Chandra Sekaran
      You can start with zero initial velocity (that is the default initial condition in ANSYS). Then based on the force and the mass of the cylinder (F=ma), the cylinder will begin accelerating.
      • javat33489
        Add an initial speed of 0, while the pressure remains?
    • peteroznewman
      What is the time history of the pressure. I don't expect it is present for all time.
      • javat33489
        Yes, it is not always. I'm trying to simulate a cap tearing off a pipe. During separation, a pressure of 35 MPa acts on the head. The plug flies into the protective sheet and I have to check if it breaks through this sheet.
    • peteroznewman
      If you have a pressure load, you need the time history of that pressure to compute the final velocity.
      It will be simpler if you assign an impact velocity to use as the Initial Condition velocity of a cap that is just touching the sheet. Then the mass of the cap and its initial velocity completely defines the energy in the system at t=0 for the sheet problem.
      • javat33489
        I came up with this idea. I moved the die close to the fox so that the contact closes. Then he made a calculation for 0.5s and pressed the pressure for a fraction of a second for 0.001s. I created an impulse to hit the sheet with a die, thereby checking the sheet for penetration. Of course, the impact force from a flying die would be less. But I do not have time, so I applied this method.
        What do colleagues say?
        I did not use the stabilization damping factor and specified the IMPACT in the solver.
        ANIMATION
        • javat33489
    • Dave Looman
      As suggested in the previous post, it's not a good idea to solve for the rigid body motion of the plug as it flies toward the sheet.  For one thing that motion can be easily hand calculated.  Mainly though, the problem is that the plug will probably fly right through the sheet.  In one time step the plug will go from not reaching the sheet to being beyond it and contact will not have occurred.  The suggestion above avoids this and provides a good solution at the instant of contact.
      • javat33489
        Yes, moving the cap to the sheet is a very good option. But apart from the pressure at the moment of separation from the pipe, I have no other input data. How then to solve this problem?
    • Dave Looman
      Perhaps a CFD analysis could compute the drop off in pressure, but to make progress on a purely mechanical analysis you could make an engineering guess on how long the pressure is applied to the plug.
    • javat33489
      I have attached the new idea and animation above in response
    • javat33489
      What do you think about my idea?
    • javat33489
      Colleagues, I have attached the archive
      ARCHIVE
      • javat33489
        What do you think about this?
    • javat33489
      I need help guys
    • Dave Looman
      The most important input quantity in an impact analysis is the velocity of the cylinder at impact.  I wouldn't even include the gravity and pressure loads.  You're going to have to make an educated guess on what velocity the projectile reaches and then specify that as an Initial Condition.
      • javat33489
        I have already written many times, I do not know the speed! I only have pressure!
    • peteroznewman
      Dave Looman already said "a CFD analysis could compute the drop off in pressure" and I agree that is one way to estimate the impact velocity.
    • Dave Looman
      Or perhaps you could make an assumption like the pressure on the plug would drop off after the plug traveled 1 inch.  Perhaps this could be an upper bound solution.  Then you could calculate the velocity at 1 inch of travel under full pressure and say it was an upper bound.  Applying this initial velocity in an impact analysis would at least give you a data point.
      • javat33489
        Interesting idea, I'll try it.
    • javat33489
      How to calculate the speed you offer in CFD? Can you tell me more about how to do this?
    • javat33489
      Colleagues, I did it. I measured the time of flight of a 1 mm plate under pressure and used it as the initial speed:
      Speed 9291 mm/s
      Here's what happened at that speed:
      Max stress 436 MPa, material tensile strength 450 MPa. This means that the part severely damaged the shield, but did not break through it. Everything is fine?
    • peteroznewman
      If the plate material is a ductile metal, you can get a more realistic simulation by adding plasticity to the material model. The simplest one is Bilinear Kinematic Hardening as it has only 2 inputs, Yield Strength and Tangent Modulus which you can set to 0.  This is a conservative assumption since a real material will have a non zero tangent modulus. If the projectile bounces off that material, that would be better than what you are showing which I assume has a linear elastic material model.
      • javat33489
        Thank you very much sir. I will add plasticity to the wall.
        And the solution itself is normal, as suggested by Dave Looman?
    • peteroznewman
      I think it is unrealistic that the cap will hit the plate at a flat orienation, spreading the impact over the largest possible area.  The worst case is the cap is oriented at 45 degrees and the edge corner makes contact with the plate and creates a much higher peak stress.
      • javat33489
        Yes, you are right, but as an initial basic calculation can be used.
    • Dave Looman
      It still appears you are starting the analysis with the cylinder far away from the target.  Are recommendation has been to model the cylinder in contact with the target.  Nothing is happening in the time before impact so it is wasted computation, but more important there is a risk the cylinder will over-penetrate the target.  As mentioned, plasticity frequently occurs in impact problems.  In the APDL Verification Manual, VM265 is a very plastic impact analysis of a copper cylinder.
      • javat33489
        Yes, I put the cylinder at a distance of 500 mm from the wall, as it stands in reality. I posted a lot of substeps so the detail didn't penetrate through. You are right, of course it is better to move the parts close to the closed contact. Over 500 mm, the speed is lost, you can calculate what speed will be 500 mm after the initial one and put the parts close. Thank you very much for your help!
Viewing 17 reply threads
