TAGGED: ansys-fluent, ansys-structural, multiphase, static
June 27, 2022 at 8:35 am
pv00170
SubscriberWhen I transfer results from fluent to static structural I get and error if I have applied multiphase.
I have done the same simulation, with static (singlephase), transient (singlephase), transient (multiphase) and the first two pressures were well exported to static structural, but when I use multiphase, It says that no pressures are found on the face selection
June 30, 2022 at 8:38 am
DrAmine
Ansys EmployeeHow are you transferring? Can you add a screenshot?
July 4, 2022 at 11:48 am
pv00170
SubscriberI have first created the workflow for Multiphase and then copied it, and modified it for doing a Single phase.
I have also included the Static Structural screenshot in which for the Multiphase it says "No pressure data was found on the selected surfaces".
I think the workflow works, since the SinglePhase is just a copy of the Multiphase, I have just changed the VOF.
July 1, 2022 at 1:45 pm
pv00170
Subscriber.
July 1, 2022 at 1:48 pm
July 4, 2022 at 2:50 pm
Ansys EmployeeIf you open up the Fluent solver have you got pressure data in the model? Ie has it run?
July 5, 2022 at 7:30 am
pv00170
SubscriberYes! Both Fluent models got pressure results.
The only thing is that Static Structural doesn't read the results when using Multiphase.
I don't know if its a problem I just encounter.
October 11, 2022 at 5:56 pm
RM
Ansys EmployeeHi,
Please try with changing the 'interpolation type' from 'Mechanical based Mapping' to 'CFD results interpolator'.Mechanical-Based Mapping only imports normal pressure.
Please refer Using Imported Loads for One-Way FSI (ansys.com) for more information.
Hope this helps you!
October 17, 2022 at 11:21 am
pv00170
SubscriberIt says:
CFD Load Transfer Summary
-- ERROR -- Cannot calculate force. Variable 'Mixture.Volume Fraction' does not exist.
October 17, 2022 at 11:59 am
RM
Ansys EmployeeHi,
It may happen due to fluent results files saved in HDF5 (.dat.h5) format and we are looking into it. As a workaround, please change the default file saving option to legacy format (.dat/.dat.gz) and then try to import load.
3930
2649
1861
1272
610
