Prestressed modal analysis
    • acakaca
      Hello everyone,
      I wonder if someone could give me a hand with my project. I am currently working on modal analysis of an assembly with multiple parts and huge number of elements.
      For the next step I would like to perform prestressed modal analysis. Is that possible without running static structural analysis first; is there another way to apply prestress directly in modal analysis?
      I am affraid that otherwise my computer will generate an error while solving the model and I wont't be able to get the solution.
      Have a nice day and stay healthy!
    • peteroznewman
       You must run a Static Structural first and link the Solution cell of that to the Setup cell of the Modal analysis to run a Prestressed Modal analysis.
      Why do you think you need to prestress the structure before running the Modal analysis? Do you have long thin sections under high levels of tension like a guitar string or large thin plates under tension like a drum skin?  If not, you will not see much difference between the normal Modal result and the Prestressed Modal result.
      If your model has a huge number of elements, you should spend some time idealizing the model to reduce the number of elements. If your model is entirely made of solid bodies, here is a list of idealizations that greatly reduce the size of the model, in order of largest to smallest impact.
      • Replace a body with a point mass
      • Replace uniform cross-section long parts with beam elements on line bodies
      • Replace uniform thin-walled parts with shell elements on midsurfaced sheet bodies
      • Use Mesh Defeaturing to remove small details from the mesh
