Prestressed piezoelectric modal analysis in Mechanical APDL – cause of fatal error
    • CW62
      I have conducted a static piezoelectric analysis to apply prestress loads to a piezoelectric energy harvester in Mechanical APDL. I am now trying to conduct a linear perturbation modal analysis restarting from the final substep of the last load step of the static piezoelectric analysis; however, the simulation encounters the fatal error below:
      *** FATAL ***              CP =  1540.578  TIME= 19:54:24
       The low level memory manager failed to return a valid memory handle for a free operation. Pointer value: 2627480032. It is likely that the code is calling for a free with a pointer that was not allocated via the memory manager.
      Is anyone aware of the cause of such an error? Is there another procedure I can follow to conduct a prestressed piezoelectric modal analysis? Any help would be greatly appreciated. Thank you.
    • Daniel Shaw
      Are there any error/warning messages issued before this final error? For example, any warning about small pivot terms.
    • CW62
      These are the error/warning messages issued during the simulation.
      /COM,ANSYS RELEASE Release 19.1BUILD 19.1UP2018041819:03:25
      *** WARNING ***CP =226.734TIME= 19:03:53
      Boundary conditions, coupling, and/or constraint equations have been
      applied on all the contact nodes (for example 1794).Overconstraint
      will occur.For deformable-deformable contact, switch contact and
      target surfaces.
      *** WARNING ***CP =226.953TIME= 19:03:53
      applied on all the contact nodes (for example 4751).Overconstraint
      target surfaces.
      applied on all the contact nodes (for example 8943).Overconstraint
      target surfaces.
      applied on all the contact nodes (for example 11900).Overconstraint
      target surfaces.
      Overconstraint may occur for Lagrange multiplier or MPC based contact
      algorithm.
      *** WARNING ***SUPPRESSED MESSAGECP =226.953TIME= 19:03:53
      applied on certain contact nodes (for example 11900).
      *** WARNING ***SUPPRESSED MESSAGECP =239.094TIME= 19:03:54
      The Sparse Matrix Solver was not able to sufficiently utilize the GPU
      accelerator device(s) during this equation solution.This can be
      caused by one or more factors such as: the size of the system of
      equations being solved; using older or less powerful GPU hardware
      relative to the CPU core(s) involved; having insufficient available
      memory on the GPU device.The check for GPU performance terminates
      for the remainder of this session.
      *** WARNING ***SUPPRESSED MESSAGECP =251.438TIME= 19:03:55
      The view for graph plots is currently NOT changeable.
      To enable graph view manipulation, issue /GROPTS,VIEW,1.
      *** WARNING ***CP =315.938TIME= 19:04:00
      A reference current value times the tolerance is used by the
      Newton-Raphson method for checking convergence.The calculated
      reference CHARGE CONVERGENCE VALUE = 7.883514722E-20 is less than a
      threshold.This threshold defaults to 1.0-12 or is specified as
      MINREF on the CNVTOL command.Check results carefully.
      *** WARNING ***CP =1358.469TIME= 19:05:08
      reference CHARGE CONVERGENCE VALUE = 2.10299423E-14 is less than a
      *** WARNING ***CP =1882.844TIME= 19:05:43
      reference CHARGE CONVERGENCE VALUE = 5.075944998E-15 is less than a
      *** FATAL ***CP =2096.578TIME= 19:08:56
      a free operation.Pointer value: 1340621376.It is likely that the
      the memory manager.
      The above error is non-recoverable by ANSYS
      ANSYS run terminated by the indicated error
      Current data base saved if possible.
    • veyselkaba
      Hello CW62 ,
      I have similar error like you . Did you find any solution. If you found , could you share solution with me ? Thank you
Viewing 3 reply threads
